1 - 11 of 11 Posts
My car has 103,xxx miles. And just recently I have noticed that dash lights in the center counsel, steering wheel and indicator lights (headlights and fog lights) flash on and off when I either 1. use the turn signal switch to indicate a lane change or 2. on there own when driving at night. What can cause this? Do I need a new turn signal switch? Prior to taking video, I was driving at night and my headlights went out, along with dash center counsel lights. They came back on and had no issues. I parked at a restaurant and recorded a small video but it is not letting me upload because mp4 format is not allowed.
Any thoughts ? **I do have aftermarket headlights and rear taillights but I have had them for over a year now with no issues, this cannot be the cause**
Thanks
Edgar
Ground issue or signal stalk issue. With the lights on try rotating the switch up past the Auto position, and they may all turn off. Could just be buildup and not good contact so cleaning could be done. Otherwise full replacement.
Thanks
Edgar
Could be a ground but I'm thinking the multiswitch is not connected well or has internal problem. Wiggle it and see if you can make it fail/work. If so check it's connection. If that's not a problem the switch(s) may be the problem.
grc, if someone gives a good response (forgeinaz) there really isn't any point in saying almost the same thing! No offense, just my take! :wink2:
  • Like
Reactions: forgeinaz
Read here many times from the guys that usually it’s a ground problem.
The ground wire from the connector of the turn signal switch assembly? I do have the trim removed from around the steering wheel assembly and exposing the switch connector..
Discussion Starter #7
I have done this where I wiggle the switch assembly and the lights (exterior and dash counsel, steering wheel controls) will turn off and back on or if I push the switch inwards and does the same thing
I was thinking more of the negative cable from battery that connects to the chassis itself. But maybe it’s the actual stalk itself!
Discussion Starter #9
if that were the case, it would have effected more than just what I mentioned. Need to see where that ground wire from the switch connector leads to under the dash.
Thanks
Thanks
I think you can try contact cleaner on the connector for the multiswitch and see if that corrects it.
You can try contact cleaner like GRC said or replace the stalk. It is somewhat common thing.
1 - 11 of 11 Posts
