Look on the forum and didn't see this posted anywhere. Just wanted to post how easy it was to replace a low beam bulb. Basically take the cap off the back of the low beam headlight assembly, quick twist 1/8 to 1/4 turn, there are arrows on the back for which way. Then you have access to the bulb which is also twisted out and in. Just grab the straight plastic piece on the back of the bulb, vertical when the bulb is locked in, and turn it counter clockwise, 1/8 to /14 turn. Popped right out. The contacts stick out the side of the back of the bulb and twisting it slides them into the slots. Very simple. Just make sure when putting in the new bulb that the contacts are in the right location. Obvious when you pull out the old bulb.
