1 - 1 of 1 Posts
Hi, The immobilizer is switched on(solid light cranking) The ring antenna is transmitting the IR signal to the immobilizer module, we need to do pin testing at module. The information we have from Alldata says to remove instrument cluster and it is located to the right in a large opening of the dashboard, clearly shows module with multiplug facing out in the image.
it is not there. The opening in the dashboard is shown as one large hole. We have to small openings, we have search n/s & o/s behind dashboard. I do'nt think the info is correct. Can someone who removed the module,(specifically IX20 not I20) guide us to where it is located
1 - 1 of 1 Posts
