I've been working on cars on and off for over 40 years and in the old days would often put
a small dab of anti seize on lug nuts. I stopped when a friend said never do it. Early on
as a kid I tightened as much as possible without a torque wrench but have been torquing
for the last 40 years or so. I restored a 1958 Alfa Romeo including and engine swap, valve
job, installed upgraded cams and re-jetted the dual Weber carbs. I had a head gasket fail
on a Friday, ran out for a new gasket and had it installed by Saturday night. Pulled the
head with the carbs and exhaust manifolds in place.
Saw posts by a mechanical engineer on a Volvo forum who said using anti seize was the
right thing to do. I decided to try it on this car and used the torque wrench.
The wheel was loose, had about 1/16" play on the hub due to the lug nuts backing off.
Never again will I use anti seize. I have seen seasoned professional mechanics say
never use it as they've heard of wheels falling off.
I didn't even think to check the lug nuts when it first started but now I'm carrying the
torque wrench in the trunk and will check them all from time to time. I washed the lube
off with brake clean today.
The car is fine again.
