Hello,
I am new here but have been turning my own wrenches for a while. Here is my situation; I ordered rear hubs, received them and months later went to put them on. I had double checked the part numbers with various online sites and all seemed right. Turns out they were wrong. The hubs I received mount with the bolt coming from the inside of the hub, but my 2011 Elantra has the hubs mounted with the bolt coming from the outside of the hub. The new hubs are threaded at the mounts, but the ones on my car are threadless and clear the bolts.
So I have two issues, getting the right part numbers and hub, and selling the new hubs (can't return them due to months ago order).
This is not the first time I have had problems with my 2011. Getting the correct brake rotors took 3 trips to NAPA and two special orders.
I will post pictures (or try) and hopefully someone else has been in my shoes and can post the right part numbers.
Thanks,
Pete from Northern NJ.
Call dealer part dept with VIN, can pull part number using VIN as assembled to car - chassis for correct number
  • Like
Reactions: J Pete
Thanks. I will give that a try. I had given my VIN at the parts place for the brake rotors, but that lead to 3 possibilities, with the last one being correct. I assume that the dealer can pull the part list that was actually used to assemble my car?
I did a quick look up here in my work area , not having VIN, I come up with 52710-3X000 at $333.87 each
  • Like
Reactions: J Pete
SBR711, Thank you very much! I did a Google image search and that looks like the part I have on my car.
Thanks again.
As for the brand new parts that I can't return, would you suggest I put them on the market place here on the forum?
Thanks,
Pete
