Not quite. The "Smart Alternator" charges while engine load is lower and stops when more power is needed for the wheels, but it doesn't actually use braking and coasting to generate current. That would be regenerative braking.The smart alternator uses braking and coasting to charge the battery...
SighNot quite. The "Smart Alternator" charges while engine load is lower and stops when more power is needed for the wheels, but it doesn't actually use braking and coasting to generate current. That would be regenerative braking.
