1 - 8 of 8 Posts
Hey all,
I've recently run into some issues with my 2011 Accent where it wont start, it simply makes a noticeably loud click noise from the engine compartment.
The main variable seems to be the temperature, on cold days I can basically say its not going to start.
I have already replaced the battery, thinking this was the most likely cause but that doesn't seem to have fixed the issue.
I have come to think that its probably either my alternator (not supplying enough juice to my battery) or my starter (not working correctly in general).
I figured before I start throwing more money at it I should check with you all and see if you had any ideas?
Thanks
Get a voltmeter. If the battery voltage is above 14v when idling after starting it is good.
2007 Honda CRV
Replaced battery already
And when cold, there is a click
Hmm, Swap starter relay
And, clean terminals of battery (don't forget to do the ground strap)
And, clean the terminals of the starter (don't forget the engine ground strap)
And, clean the cable ends
If that doesn't work then wait for warmer weather ... ???
Had this same problem on my 2004 Mercury Sable, had a new battery in it, and alternator/regulator was functioning just fine.
If the temperature was above 15 F no problems starting, but below would not start.
The solenoid in the starter would not function (activate the starter bendix) under cold temperatures.
I had the starter removed by my mechanic and took the starter to have it rebuilt with a new Ford Specification solenoid), Ford Spec. new brushes (original one still had plenty of life), the bendix even look fine (but replaced with new Ford Spec. Bendix).
I paid $35 to have it rebuilt, a lot cheaper than a new or rebuilt starter from a auto parts place.
Just look around for a place that rebuilds, starters, alternators, and have them replace with Hyundai OEM parts and you should be good to go.
I don't know how someone could rebuild a starter with a new solenoid and bendix for $35.
Do people work for free in the US? Do starter motor parts grow on trees over there?
$35 is roughly £25 in the UK. You couldn't buy a used unit from a breakers yard for that over here.
Just had this same problem and had new battery also. Crank got weaker as it got colder out and one morning wouldn't start at first although it eventually fired up. I replaced the starter and all is good. Even better actually--the starter is much more quiet and starts more quickly than it has in a long time. First real problem in 62k miles.
I must have some Scottish blood in my ancestry that I am not aware of ! :grin2:
1 - 8 of 8 Posts
