I purchased a 2.0L turbo Sonata in 2011 after one drive. I believe it was ahead of its' time relative to other small cars. The performance was on some levels equivalent to the Mercedes E500 I used at the time which only delivered 14 - 15 mpg around town.
I have had problems with warrantee issues wherein dealer refused to warrantee the oil line to the turbo which blew up and sprayed oil all over the engine (fire issue). There was a recall but I was refused reimbursement. Additionally my paddle shifters failed at about 45,000 mi and the dealer claimed they were not part of the transmission even though they shifted it. Almost had a serious accident when they failed as I use paddle shifters for compression to aid brake use. It is probably time to notify NHTSC as this is a major safety issue. I do love this car for general driving.
2017 Sonata Sport 2.0T
Sounds like you need to go to a different dealer. Both of those items are covered under the 5-60 warranty and the oil line was a recall so there is no reason to deny the claims. Unless you were passed the 5 yr point and then the paddles are not part of the major drive train so without a extended warranty they are not covered.
Oil line is a recall part.. call Hyundai Motor for re-imburse help.. make sure it has current style line
Paddles is 5yr / 60,000
