Hi all I'm getting an engine management light when Ive plugged in my el cheapo reader it gives 2 pending faults for p0011 and p0014 ie both exhaust and inlet
I've had the vvt valve and sensor changed on the inlet valve which hasn't resolved the issue.
Seems to drive OK maybe down a bit on power but not 100% sure.
Discussion Starter #2
As this seems to be common problem I thought I'd add a update post.
Had a good read of the Haynes manual and I had a bit of hunch.
According to the Haynes manual with the engine in tdc on cylinder one as indicated by the marking on the fan belt pully and the casing.
With the camshaft cover removed there are two lines on the each of the camshaft phaser that should align both point at each other and be online with the top of the cover.
My my car one is slightly pointing up and the other pointing down. And when turning engine over by hand slacking of the timing chain can be observed.
So it's looking like it's warn tensioners. So going to order a full timing chain kit for the car and I'll update back.
