I have a gentle thud thud thud thud thud noise that can be heard inside the cockpit with the best time to hear it when the vehicle is stopped. Can't ready hear it from up above when the hood is lifted due to injector noise but if you listen down in the drivers footwell you can. It's not there all the time but you do know when it is because the vehicle is nice a quiet from inside when it is not happening. Any ideas such as tensioner noise or ????
I do notice some very light hammering/thudding noises when the engine is idling and everything else is dead-quiet, but I attribute it to normal engine operation as it resonates through the frame and insulation. Hyundai deserves praise for the smoothness of its Lambda engines, but no engine is 100% quiet if you listen closely enough.
As for how you drive with your head down in the footwell area, pistol, I'll leave that one to speculation :grin:
I knew that I was in for some comment like that Don :)
It is a very strange noise because it does not happen all the time.
SENIOR MODERATOR
I take it you picked up your 2010 replacement, then?
