When I use my front windshield fluid it sprays out the back one. When I use my rear fluid it sprays out the front. But at the same time the wipers are correct front wipes on the front. What is causing this?
It sounds like maybe someone has swapped over the pump harness connectors so the wiring from the front washer switch is connected to the rear washer pump. The other possibility is the hoses have been swapped over.
Have you had any work done in the area of the washer pumps recently?
