1 - 9 of 9 Posts
My check engine light came on the other day, and I went to Autozone to have the code read. Of course, that indicated the camshaft position sensor was detecting a fault. I read through all the posts relating to the fault, headed up to my local Hyundai dealer, and picked up the oil flow control valve for about $50 plus tax. While I was there, I figured I might as well have them do an oil change, since it was way past due. No point in putting in a new part with dirty oil..right? They did the oil change, washed the car and I was ready to roll. My plan was to replace the part myself, but magically, the check engine light has not come back on since. I hope it remains so, but I will keep everyone posted on the situation.
Aftermarket oil filters will also cause that DTC. A lot of times just changing the oil with an OEM filter clears it right up.
I have a 2006 Sonata 2.4 with 137000 kms Car runs fine no problem starting or running at all.. It keep giving code p0011 which i have read about online and here, I changed the oil and filter as well as the ocv. I even changed the camshaft sensor.. check for loose wiring but dont see anything wrong. The code keeps coming back sometimes it takes a day or to other time its only a few miles. Does any one have any other suggestions as to what be the cause. again the car works great.
2006 NF 2.4 may have a stretched/jumped chain... been there.... there is a nylon screen for oil flow to head,, but it is located in the deck, sandwich by cylinder head..
What's with all the stretchy timing chains these days. Every other week we were seeing cars come into the VW dealership where I worked with stretched chains (avoid VW TSi engines). It's something that was pretty much unheard of 10 years ago.
I don't think the timing chain is stretched as the car work great. Just can't get the engine light to stay out. Its been 6 months since first came on still works like a new car.. will have to look for the screen filter to see if its plugged.
1 - 9 of 9 Posts
