Does anyone have a link a to the drivers seat wiring diagram? My daughters seat is reclined all the way back. I believe the switch is bad because it had no problem moving backwards. I would like to bypass the switch or power the other side of the contact.
Can the motor be removed from the gearbox and the shaft moved manually to bring the seat back up?
Any help will be greatly appreciated!
Replace the switch,, known problem part through the yrs
Pop the decorative button off, and play with the shaft, may get it to move back for time being
Thanks for the help! I was able to move the seat back up by adding power and ground from another source while I wait for the switch to arrive.
2020 Santa Fe SEL Plus
It could be the stop limiter switch.
If the switch is not used often, the switch contacts get corroded. Operate both switches a few times should "clean" the contact surfaces making good electrical connection again.
