Hi All
Engine has developed a cold start rattle, sounds like timing chain, rattle lasts for no more then two seconds. Doesn't do it every time. Oil and filter changed less than 10k miles ago. Any other CRDi engines with cold start rattle? 77k miles in total.
Discussion Starter #2
Panic over (hopefully): broken support leg for the acoustic insulation cover for the top of the engine. Looks like it was previously broken and previously glued by others. Cover now sitting in the lock-up.
It wasn't phaser rattle? Never heard of an engine cover doing that.
FYI, I had similar symptoms and a similar cause. In my case it was the air intake cover that was loose and causing an annoying rattle.....a couple of loops of insulation tape has cured the noise.
Cheers
Skiwi
Thanks for the replies.
Broken and poorly repaired by a previous owner, cover will remain off for now.
