Dont...
PCM update for DTC logic if I recall... Got specific DTC ?
DCT was P0328 Knock Sensor 1 Circuit High Input
other codes read P0304 Cylinder 4 and replaced coil
P0011 'A' Camshaft Position -Timing over advanced or system performance
P0496 Evaporative Emission System High Purge Flow
Description:
13-FL-012
ECM UPDATE – MIL ON DTC P0300-P0304, P0128, P0328, P0461
NOTE: This bulletin supersedes 10-FL-004 and 10-FL-011
This bulletin provides information for an ECM diagnostic code logic update on some Accent 1.6L
vehicles that may experience the following DTC:
- P0300: Random/Multiple Cylinder Misfire Detected.
- P0301: Cylinder 1 - Misfire Detected.
- P0302: Cylinder 2 - Misfire Detected.
- P0303: Cylinder 3 - Misfire Detected.
- P0304: Cylinder 4 - Misfire Detected.
- P0128: Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature).
- P0328: Knock Sensor 1 Circuit High Input.
- P0461: Fuel Level Sensor A Circuit Range/Performance.
Do we indeed have lumpy-bumpy felt misfire.. or run fine with stray 0304... true mifire --> coil most of time,, plugs cheapies,, 30,000 interval,, step up into NGK Iridium and get longer life
0496,, replace purge vale
  • Like
Reactions: Red Raspberry
