I found an aftermarket headlight housing for my 09 sonata but im not sure if it will fit. If you read the description carefully it states that "this item is produced to fit the slightly re-designed 2009 Sonata (NF2/Transform) model." I emailed import shark and this was the response "The manufacturer only list it for the Transform model." I want to know how the headlight housings differ from the 2009 Hyundai Sonata and the 2009 Hyundai Sonata NF2/Transform.
The 2009 is called the Transform in Korea.
As hideous as they look they will fit your Sonata since its the same car.
Edit -
And they look to be just the inside of the lights, so you'll have to bake (or heat gun) your stock headlights to open and install these.
Seems like a lot of trouble... :whistling:
