I have never heard of it being called a CCV. I have heard of that item described as a Fuel Inlet filter and when i asked at the dealership parts counter recently he said it was NEVER replaced by the techs there.
There is a PCV on the rear corner of the back valve cover of the driver side. The manual doesn't say about much about it, but i have had to replace mine a number of times and i am at 90k miles. It caused drive-ability problems for me. Two tips on replacing the PCV:
- You do NOT have remove the intake plenum to get to it (just remove the throttle body and lay aside, give the throttle body a good cleaning while it is off too)
-The part is about $24 from Hundai but if you go to a good auto parts store it is fully interchangeable with a standard PCV for a Ford (don't have p/n sorry)
