I currently have a 2009 Elantra SE and noticed that some of the window switches not working properly. I took the door panel off and took the switch out and noticed that it seem to work fine pushing down on the correct sides as the window when up and down. Is there anywhere to just buy the small window switches without having to buy the whole thing. It seems the plastic on the switch is wore down and just needs to be replaced. As I said the component part of the switch works fine. Thanks
Supporting Vendor
