Hi, having a hard time finding where the Crankshaft Position sensor
location is on our 2009 Elantra. This is for the P0016 Code.
Can anyone point or provide a diagram or pic or video? So much
appreciated. This is the last code I have to fix :)
I think the crank position sensor is at the front of the engine just to the right of the catalytic converter. It's the sensor with the 3 terminal connector.
But why would you be looking at the crank sensor to deal with P0016. That's not a crank sensor trouble code. It's a camshaft timing code, so you should be looking at the timing belt and CVVT system rather than the crank position sensor.
456857
front of the engine, driver side of the Cat.
P0016 is Crank shaft position/ Camshaft position Correlation
you would have to check the signal of both to find the failing sensor
