The key was put into ignition and turned but would only go as far as on position and would not return to off position. Key came out in on position, but I had to disconnect battery so it wouldn't die until it can be fixed.
2007 Honda CRV
What does the gear select indicator say when you put it park?
If it reads correctly then switch in gear selector may be broken??
Looks like a problem with the ignition barrel. Shouldn't be able to remove the key in any position except off and lock.
