Hi,
Could someone please advise me where the Purge Control Solenoid Valve (PCSV) is located on my 2008 Tucson 2.0 CRDI GSI.
Thanks
Hi,
Thanks
What makes you ask about the purge valve? You may want to find out a little more about this system. It'll be in the engine compartment and has a hose coming from underside to valve and from valve to intake.
Simple EVAP system (US) below.
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
Here's a fun fact about EVAP systems....a CRDi engine doesn't have one.
There I go making assumptions again. I better stick with Ford and GM forums...:smile:
Does it make you wonder why he asked the question? I can't help but wonder. Maybe he used a generic scan tool to retrieve a code his system doesn't support......
Oh man look what I have done....I can't leave this place now....Now I'll have to stick around to find out what's going on.......You regret it yet? :)
