How do I remove the ashtray assembly. Coins fell behind and keep rattling around. What the easy way to remove them. It's a 2008 Santa Fe Limited
QUOTE (joycee @ Jul 28 2010, 08:17 PM) index.php?act=findpost&pid=345711
Just took mine off to put in a new head unit. The ashtray is built in to the 'wood' grain piece that goes from the steering wheel to the glovebox. Easiest way to pop it off is to take the panel off below the steering wheel (has a few clips and one or two screws), then you have to pop the wood off with a small flathead screwdriver (wrap it with tape so it doesn't damage the wood panel). There are quite a few clips and you have to leverage it a bit to get it off, but it's easy to do once you get started, should only take you about 20 minutes to take it off and put it back together!
Good luck!
