I had one of the 2 front drain holes clogged which caused water to leak into the front overhead of the SUV. I spoke to a tech in the parts department at my local Hyundai dealer and he indicated there are also 2 drain holes toward the back of the vehicle starting from the second row.
According to the diagram, the picture of the rear drain tubes were well past the back of the sunroof area.
Anyone know how to get to the rear drain holes? Pictures or video would be great.
Thank you
They usually come out at the fender wells. Probably need to take the wheel and fender liner off to see them.
I have used compressed air blown into the sunroof drain holes to blow the tubes free before.
I was referring to the location of the drain holes at the sunroof area, not the exit tubes by the tires.
I found and cleaned the 2 in the front of the sunroof, but can find the other 2.
