I want to hard wire a second 3.5mm female extension directly behind the factory dash mounted AUX input. My car only has an AUX port without the USB. Can anyone help identify the colored wiring on the harness? Thanks!
I can only go as far as connector on back of jack...
1 - GR - Illumination negative
2 - P - Illumination positive
5 - BR - AUX In Right
6 - P/B - AUX Detect
7 - B - Ground from chassis
11 - Y - AUX In Left
12 - W/B - AUX Ground (drawn out in diagram as shield to part of harness)
Thanks for sharing. I didn't realize I might need more connections than four connections to make this work. There's just left, right, mic (I assume this goes to AUX detect), and ground from my 3.5mm extension cable.
Will my radio's AUX input function work with the following connections?
3.5mm extension left -> Pin 11 - Y - AUX In Left
3.5mm extension right -> Pin 5 - BR - AUX In Right
3.5mm extension mic -> Pin 6 - P/B - AUX Detect
3.5mm extension ground -> Pin 12 - W/B - AUX Ground
Am I missing something?
Cannot answer, I am not a radio tech,, I turn wrench and deal with driveability concerns
