The heater has stopped working in our 2008 Elantra. I want to check the easiest thing first - the fuse. However it's not obvious which fuse that is from the owner's manual.
Can someone identify the fuse that might be responsible for the heater not working?
Thanks.
Turn the fan on, and thump the fan motor housing.
In reality, checking fuse is just a visual reference, you need to actually inspect electrical at fan motor connector with DVOM and see the number value displayed for voltage on the circuit to see that it making it to the component.
I be more interested to know if it has an electric blend door motor.. they crpa out on our other models.
