Without and rain or anything our drivers side floor gets soaked. Is there a known problem for this. And is there a easy fix?
Most car has floor drain hole covered with rubber plug. Pull up the carpet & check for damage. If so, it's easy fix
Do you use the A/C? Can you see the water drip under the car as it's running? If not, it's possible your A/C drain hose is clogged and backing up in your floor.
