I've got a weird problem here and I have no idea if the two are related...
My wife has a 2007 Tucson (2l or whatever the smallest is, 2wd). A few months ago it started just randomly shutting off while driving, would restart after a try or two. Had all the markings of a bad CPS, so we had that replaced with an OEM part. It started shutting off on its own again. So we were told perhaps fuel pump, so we replaced that. It has shut down once since, in probably 8 starts since replacing it, so we are not sure if it is corrected.
Today we were driving and the CEL came on, we were about a min from AutoZone, so we went in and had them read it.
The codes are ALL over the place. I'm wondering if anyone knows what may be the cause (perhaps they share somethign common), could it be related to the issue above, and, lastly, why in the world would the CEL come on now instead of earlier.
I don't have enough posts to upload Photos or Links to the thread, so the OBD results are transcribed below, they were in this order on the scanner.
C1611 CAN Time-Out EMS / ECM (ABS $28)
C1612 CAN Time-Out TCM / TCU (ABS $28)
C1503 TCS / ESC (ESP) Switch Error (ABS $28)
C1513 Brake Switch Error (ABS $28)
P0560 System Voltage Malfunction (CURRENT) (ECM $11)
P0170 Fuel Trim (Bank 1) (CURRENT) (ECM $11)
P0171 Bank 1 System Too Lean (CURRENT) (ECM $11)
P0170 Fuel Trim (Bank 1) (CONFIRMED) (Mod $00)
P0170 Fuel Trim (Bank 1) (PENDING) (Mod $00)
P0171 Bank 1 System Too Lean (PENDING) (Mod $00)
Thanks for any help you all can give!
