Can anyone confirm if a set of 2007 OEM 16" Rims will fit on a 2010 Sante Fe?
Believe the rims specs on a 2010 are 5 lug x 6.5", 67.1mm hub diameter, 41mm offset.
Can't find the 2007 16" specs.
Cheers
Same for 2007~2009. No change to hub diam, offset, etc.
Just be sure that when you pick up rims, you get ones with the right hub diam for the Hyundai. There are some with identical bolt patterns for Toyota, etc., that have smaller hubs - just a couple of millimeters, but too small to fit the Hyundai.
