Hello and welcome to the forum 00000732
I've never had to replace one on a Santa Fe, but the washer nozzle (jet) usually just clips into the scuttle trim (the black plastic part at the bottom of the windscreen). Doing the job by the book, you need to remove the scuttle trim and disconnect the washer hose off the bottom of the nozzle, then press in the clips that secure the nozzle and lift it out of the trim. But to remove the scuttle trim you'll need to remove the windscreen wiper arms (which are often rusted on) and there will be some plastic rivets that will need to be removed too. It's not that big a job....if the wiper arms cooperate.
I need to replace a windshield washer nozzl. Can someone help?
If it's the same as AUTOSPARK suggests follow his advise.
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
