2007 Santa Fe tailgate will not open. When I use the key fob it goes through the lock and lock motion. When I grab the handel and squeeze the tailfate does not open. I took inside pannel off and checked and nothing seems broken. Also, sprayed wd40 to lube.
Are you sure the handle is in the "home" position before unlocking.. they get stuck in the "squeezed" position and lock will not operate with handle squeezed..
