I have a 2007 Hyundai Santa fe have recently had the neutral safety switch, battery, alternator, harmonic balancer, timing belt, lateral link, toe, ball joints, tires, purge valve toe, switch under brake pedal, water pump, valve vent solenoid, air filter, oil change and new tires. I'm currently at 171,400 miles and today I go get in it, it starts fine, thethereby initially would not turn though. then, I get it too and after shutting off it won't start, about two hrs later same thing, the check engine light is on and I do know it's due to fuel let else sensor b being out, but troubled by why after having timing belt, alternator, water pump and harmonic balancer just replaced a day ago it's now doing this.
