1 - 20 of 25 Posts
My daughter has a 2007 Hyundai Santa Fe Diesel. Money spent on it in 3 years is nothing short of insane. Can anybody please help? It idles fine and drives fine up to 75/80kms, the MIL is on. The DPF, TURBO, FUEL FILTER, AIR FILTER and MAF SENSOR have all been replaced! Any advice will be greatly appreciated. Cheers
WOW...that's a lot of parts you've had replaced there. I assume all those parts weren't fitted in an attempt to fix this current issue?
You say the MIL is on so there must be a trouble code logged in the engine PCM. If you can share the codes with us that might give us a clue about what's going on with the engine. It's kinda pointless offering advise when we don't know what the PCM is getting upset about.
Thank you so much for replying so quickly! Sorry I forgot the code. P0237, the turbo was replaced about 9 months ago and engine put back together(dealership pulled everything apart to diagnose why white smoke was billowing from the exhaust), long story short, they quoted $13500 for new engine, father got involved, another mechanic diagnosed turbo. The car was ok till July, it was stalling and running crap so another mechanic installed a new DPF, said mechanic wrote “cleared all codes, test drove, drove ok”, and advised that further testing to check why DPF blocked! We ran out of money. My daughter has only driven 200 kms since new DPF, and didn’t realise anything was wrong until she drove on the highway.
I rang DPF mechanic and was told it must be injectors $2000 to replace. A lot of questions from me and he wasn’t happy. So I decided to google and ask questions, I’m no mechanic but I try. I replaced the MAF sensor, fuel filter and air filter.(trying to help my daughter), I also found that the MIL light was missing a bulb after I took the dash apart. 3 mechanics quoted over $400 to diagnose why the check engine light wasn’t illuminating. Sorry for such a long post but I wanted to give you an idea of the problem.
If we try to go over 80 most times it just won’t, even with pedal to the floor, but it doesn’t over rev either. Then sometimes we can get to 100 but as soon as we have to slow down or touch the brake it happens all over again. Not sure about full throttle from stop but I’ll ask my daughter and let you know.
Discussion Starter #8
My daughter just tried full throttle from start and she said the car revved up to 4000 revs but wouldnt change gears until she eased off the accelerator. Cheers
OK, you have P0237 - Boost Pressure Sensor Low Input logged and that explains why the engine performance is so poor.
The trouble code means the engine computer can't control the turbo's boost pressure so the computer has basically switched the turbo off as a fail safe measure, preventing it from producing any boost. This code is due to a sensor circuit fault. Although it's a boost pressure code, it has nothing to do with the turbo itself.
If you have a voltmeter and a pin/needle I can tell you how to check the boost sensor wiring. The code says Low Input which means either the sensor's power supply wire is open circuit/broken, or the signal wire is open/short circuit to ground. Testing the voltages at the sensor connector should give you a clue which fault your dealing with. And I suppose the very first thing you should do is just make sure the sensor is actually plugged in. Sensor location shown below :
Discussion Starter #10
Thank you so so much, I will have the car here on the weekend so I’ll do what you advised. I’ll let you know how I go ?????
Discussion Starter #11
Hi Autospark, me again. So I have replaced the boost pressure sensor and now the code is P0238. Is this going to be a big job to fix? Any help would be greatly appreciated. Cheers
That's impossible to know when we don't know what the problem is. A 238 code means the exact opposite to the code you had originally, the output is now too high. Strange that the sensor signal would swing from one extreme to the other just by changing the sensor. Was the new one a genuine Hyundai part?
Discussion Starter #13
It was from Repco and definitely suited for the make and model.
I was going to ask what were the results were of the testing prior to replacement, we don't even know if supply is normal?
The OEM is 3930084400 and it's fitted to every turbo Hyundai I can think of. REPCO are ripoffs too at $200. New can be had for about $70 or local wreck may yield one.
1 - 20 of 25 Posts
