I have a problem with my car starts then stops. There is no problem with the fuel getting to the injectors but seems as soon as the initial fuel from the fuel pump is gone it stops.
It starts no problem every time just cuts out again?
Hope someone has some ideas.
Brad
I would start with checking that the electric fuel pump in the tank is being supplied with power after the engine has started. There is usually a terminal on the engine bay fusebox for that purpose, marked F/PUMP CHK on the fusebox cover. Connect a voltmeter to the check terminal and check that there is 10V while cranking the engine, and 12~14V once the engine is running.
