I'm in Australia and have a 2007 Getz 5 door hatchback.
At most engine revs, an annoying buzz/rattle can be heard from somewhere under the dashboard. The noise is there when the car is stationary or moving.
I have tried pressing down hard on the top of the dash but the noise doesn't stop. Is there an easy way to get deep under the dash? I am suspicious a foam or rubber pad or spacer may be worn, I had a similar rattle in the driver's door panel once. I replaced all of the hard foam blocks and it was fixed.
Thanks,
Dave
Hi MyGetz, try dropping the glove box to give you a bit of extra room or you might have to remove front of fascia to get really good access, use the search function to find the "how to's", good luck with it... I hate rattles etc with a passion!
Guys
Have you had an engine mount replaced by Hyundai. If not it could be the cause of the vibration in the car. This happened to my son's car and we had it fixed under warranty.
regards
Gerry
