Anyone had this problem with alternator......Alternator checks out good but will not charge battery when running
If the alternator checks out good (off the car, I assume) that must mean there is a problem with some other part of the charging system. So why not get whoever tested the alternator to test the charging system as a whole, then they can tell you what the problem is and what needs to be done to fix it.
