Hi can anyone help , My Tucson 2.0gsi has started leaking on the drivers side . The leak didnt seem to be slight the carpet was damp at the door. I have checked the door seals and they seem ok . During heavy rain the leak has got a lot worse and the whole carpet is wet . Lots of water as I used towels to help dry and could ring them out with the water that was beening lifted.
Has anyone got and experience of this happening to them
Welcome to the forum
Try take out the passenger side carpet. On most vehicle, there is a round rubber drain plug on the floor It's been 7 + years, check the rubber for rot.
GL
Hi, Is your Tucson equipped with a factory sunroof? If so check that the drain holes are not plugged. Might have to use compressed air at the drain holes to blow them clean out. Had the same problem with my HHR that I traded for my 2014 Tucson and that was the same issue I had with that model.
