1 - 11 of 11 Posts
I have a 2006 Tucson 2.0 CRDi - that has developed a nasty habit of not starting (without quick start spray!) but generally runs fine once started. I have however also had a few complete engine cut outs whilst driving - followed by the no start issue.
Its still an ok car and has now clocked up 130k miles and I want to keep it going for a while yet.
I have bought an OBD reader (to successfully reset a latched airbag light) and managed to find a few engine codes:
P0336 Crankshaft position sensor A circuit range/performance
P1300 Crankshaft position-Camshaft position correlation
P0100 Mass or Volume air flow circuit
From the above fault messages, would you suggest a faulty crank shaft sensor?
If that is faulty, I presume that the ECU would not 'see' any engine rotation during start and would therefore not turn on the injectors?
Does the ECU have a backup mode to keep the engine running without that crank shaft signal? I am just trying to understand the intermittent starts and why it runs at all once kicked into life with quickstart spray! (which I don't like using)
Would you change the camshaft sensor and the mass air flow sensor as well as the crank sensor?
Does anybody know where I can get a copy of the workshop manual for this car/engine?
Thanks in advance for any advice.
This is often a symptom of a fuel leak, usually caused by an injector fault.
This is often a symptom of a failing crank position sensor. It's not uncommon for Hyundai crank sensors to fail when they get hot then start to work again when they cool down. That can cause the engine to cut out while your driving and not immediately restart, but it will restart after the engine (and sensor) has cooled down.
Hi Phil's I have the same problem with my tucson 2litre automatic crdi can you tell me what you do because now I'm tired I already change the camshaft sensor and crank sensor but is same I can start the car only with the quick start sprays pls let me know when you done your car
I have the same problem with my tucson 2litre automatic crdi...I can start the car only with the quick start spray
See post #2. You probably have a leaking fuel injector. I suggest you have an injector leakoff test carried out. That will probably tell you which injector is causing the problem.
1 - 11 of 11 Posts
