Hello everyone my name is eli, I'm from Israel.
I own a 2006 petrol 3500cc V6 terracan.
1. Myengine started to burne oil, when i am starting to accelerate after a stand still (about a 30 second or more) a small cloud of burned oil exit from my eagsos.
I suspect the value seales.
2. After a long drive the water at the coolant reservoir starting to buble.
I suspect heads gasket.
I made a compression test, the results are.
cylinder 1 - 210 psi
Cylinder 2 - 170 psi
Cylinder 3 - 170 psi
Cylinder 4 - 200 psi
Cylinder 5 - 190 psi
Cylinder 6 - 200 psi
After that i made a leak down test, the results are.
Cylinder 1 - 20% leak from intake must be intake valve.
Cylinder 2 - 20 leak from crank case (must be piston rings)
Cylinder 3 - 3% leak
Cylinder 4 - 2% leak
Cylinder 5 - 0% leak
Cylinder 6 - 2% leak
I started to disassemble the engine and i am about to take off the heads.
What do you think about my results?
Can you tell me what is the compression should be by the manufacturer?
