Trying to change the spark plug on 06 Sonata I4. But got a problem removing the cable connector. Pulled the little black clip back on the connector, then I couldn't figure out how to pull the connector off. Should the black bracket outside of the white connector be removed first?
There is the initial sliding tab that locks the paddle from being depressed to release connector from coil..
Worst case, unbolt the plastic harness tube there and just the coils up while still attached to the pigtails.
Silly DELPHI connector locks, big pain in butt for no reason.
Finally get it done!
The black tab needs to be removed from the white connector, so that the white connector can be pushed down at the end.
