I've discovered a rusted hole leaking oil from the oil pan on my 2006 Sonata GLS 2.4L 4 cylinder.
Trying to find a replacement oil pan but I'm not having any luck online. The oil pan for the 3.3L is for sale everywhere, but not for the 2.4L.
Googling suggested the OEM part number might be 21510-25051 but I can't confirm that.
Does anyone know where I can order a replacement oil pan online.
Thanks.
Walk into Marhoffer and visit the parts counter, they can order it for you, it'll come out of the Chicago region (Aurora) PDC to dealer in couple days.
Local Kia dealer order it also, come out of same building in Aurora IL.
Part appears to be correct, I can check in morning, but Hyundai dealer be the easiest way to get correct part the fastest.. you'll want a tube of RTV also, motor oil and filter, and drain plug ring
Thanks, that's great. I was suspicious that the dealer might overcharge for the part which is why I was trying to find it online.
I'll try Marhoffer then.
