Has anyone installed a after market amp, and had problems. Everytime I connect it to the power the fuses keep popping. I've installed several amps previously and never had an issue, does anyone have any suggestions or information on installing an amp in this model car that i might be unaware of???
How are you wiring it? What fuse?
00000732
Thanks,
Welcome aboard.
The amp doesn't care what car make and model it's getting installed into, all it's looking for is 12v. If it's the fuse on the amp that's popping as soon as you hook it to power, either your wiring is shorted somewhere and is causing the fuse to pop, or the amp is internally fried and is causing the fuse to pop. The car itself has nothing to do with it.
