supporting vendor
As the title states, there has been a recall due to possible corrossion problems with the right front axle. The recall involves model year 2006 to 2011 Azera sedans made from Sept. 27, 2005 to Nov. 22, 2010.
Even if you believe your vehicle does not fit these descriptions, it should be looked at and verified!
Call your local dealer to find out detailed information and whether or not you may/may not need the car to be serviced!
Link to an article with some information
The piece refers to rear wheel alignment, and only in a number of cold-weather states that use salt in Winter:
In the corrosion issue, it was found that road salt used in cold-weather states can lead to rust on the steel on the underside of the vehicles, which can lead to misaligned real wheels, according to a filing with the National Highway Traffic Safety Administration.
The recall involves model year 2006 to 2010 Sonata sedans made from March 1, 2005 to Jan. 21, 2010, and model year 2006 to 2011 Azera sedans made from Sept. 27, 2005 to Nov. 22, 2010.
<snip>
The road salt issue affects vehicles that are or were registered in 20 U.S. states and the District of Columbia.
Those states are Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, and Wisconsin.
