Hello, im new to owning and driving a Hyundai. I bought this car used, and didnt notice that the driver side window only goes up to the top seal, leaving a small but obvious gap and water can get through! The window doesnt seal completely, so can someone please help me. I need to remove the driver panel.
and do so without damaging anything. thanks
i cant tell what bolts adjust window height.
Would you please follow majic12 's advice, register with that site and pull up the repair info on your screen ?
go to shop,xg,2004-g3.5dohc,body,exterior,front door
Briefly reviewed: No adjustment for maximum window height. Only adjustments for glass tilt vs door & car body ('bolts' present that work on the glass guiding rail so called 'front channel' and the regulator itself). Maximum window extension reached when glass carrier hits upper hardstop.
I can only suspect that the glass has slipped inside the carrier (or even screws have loosened and eventually fallen out ...) and may need to be repositioned and tightened.
Or the regulator-motor assy is faulty and has reduced travel range.
