Hi All,
Just wondering if any of you have come across my problem. I have a 2 litre petrol Santa Fe and it won,t start after running for a few minutes. When left lying for a while it starts with no problems. After starting up it runs for a few minutes with no issues and then stalls again.
Thanks
To me this sounds like a fuel delivery problem. Possibly a clogged fuel filter unable to deliver enough fuel to keep the engine running.
Do you get a check engine light? Have you had the system checked for trouble codes?
The problem may be due to a bad crankshaft position sensor, although I'm not sure how much of a problem that has been on the four cylinder cars. It's a known issue with the 2.7 V6 after the mileage gets higher.
