I currently have a 2005 Hyundai Getz 1.3 ltr 2 door auto. The car has developed a problem when cold and driving up an incline it will lose all power and eventually stall.
We have a small incline near home when driving up the incline the car will increase speed and change gear as normal, until close to crest when the car feels it needs to change gear but it also loses all accelerator power and then it will stall.
After pulling car over, placing into park to restart, the car will kick over a bit then start, the idle is rough for a few seconds but then clears and is normal. If i turn around and try the incline again it will not replicate the issue. It will only do it once, when cold and on an incline.
I have had transmission fully serviced, new fuel pump installed, crank angle sensor replaced, Auto electrician has tried to find any faults, this problem will not register any fault codes. After 3 mechanics, Auto electrician and a transmission specialist look at car i am in need of some help please.
