Hi guys. I am having some problems with my 2005 Hyundai tucson crdi 2.0l
The car cranks but not starting. I tested power of the injectors and they is no power and also when you put on the ignition, the pump runs for few seconds and stop and it doesn't pump at all when cranking. Thanks
No power to the injectors on a CRDi engine isn't necessarily a problem (depending on how & when you tested), but the pump not running during crank is often a symptom of a faulty crank position sensor.
It's the crank sensor that tells the engine control computer that the engine is turning. If the computer isn't seeing a signal from the sensor it doesn't know the engine is turning so it wont switch on the fuel pump.
