Ive had the radiator, and water pump replaced about 30-40k miles ago. Everything up top looks clean, with zero visible signs (or smells) of any leaking. But it seems like I have a slow leak, almost right next to the passenger side tire. Given how cramped everything is, and my lack of knowledge on this, I figured I'd check here to see if anyone has run across a similar problem. Appreciate any help/suggestions on what to check.
Does it loose coolant? Are you sure the leak isn't water from the AC evaporator?
Yeah, my reservoir was completely empty. After filling back up, I'm definitely noticing a loss. Just seems like a weird spot to me.
You'll need to take some stuff off so you can see where it's coming from.
