· Registered
Hi all. Hope someone here can help me out. Have a problem with an early 2004 trajet 2.0 petrol. Car came in for a service yesterday. Was running fine until we replaced the plugs after which it developed a severe misfire. I have a spark at all four plugs, I have fuel and a good spray pattern from the injectors but still the car is only running on 2 cylinders (no 1 & no 3 are dead) I performed a compression test and all seems well, i've tried new coils, i've replaced the wiring loom that powers the injectors and coils. I'm aware of an issue with the wiring to the cam sensor on this model but it seems fine on this car. My diagnostic equipment is only giving me P0303, cyl 3 misfire detected which doesn't help me any. I'd appreciate any help i can get on this one as it's driving me up the walls :(
· Premium Member
welcome to the forums stony :00000732:
l'm not trying to teach you to suck eggs because it sounds as though you know what you're doing, but its a big coincidence that this fault only started after the plug change, have you tried refitting the old plugs? (l was thinking along the lines of retracing you steps)
