1 - 1 of 1 Posts
Hello,
I have 2004 Sonata that has a slight hesitation problem while accelerating and the gas miliage is poor. I replaced the TPS and spark plug wires and the problem got worse. When i put everythnig back together, I applied Dialectric greese to the wire caps. Has anyone experianced poor performance after using dielectric greese? Is it possible I installed the TPS wrong and the throttel linkage is not rotating the TPS correctly? Does it need to be installed a certain way to engage the switch spring tabs? Thanks
1 - 1 of 1 Posts
