Replaced O2 sensor, among every possible other sensor and my car still has issues. Newest one being looses power, hesitates under load and burning fuel. Replaced fuel pressure regulator, fuel lines, vacuum lines. No codes coming up, I'm at a loss.
Restricted exhaust.
I'm so confused about up stream/down stream, I know it's in bank 2, facing the engine it would be located to my right, driver side.
more info would be good, do you have v6 or 4cyl, when the car is cold if you are comfortable doing so assuming you have a v6 try removing part of the exaust preferably before the 3rd cat converter or at least dissocnnect it and move it out of the way give it a start up, it will be LOUD! but drive like that for a bit and see if this helps your issue. I feel grcauto is correct on this one
